Z3 Roof Frame Removal?
AntStark
Hampshire
2002 3.0 Sport
The roof frame on my newly acquired 3.0l is totally mullered. I didn’t even contemplating fixing it and picked up a decent one with a good liner really cheap on ebay.
Question..I know how to release the sticky stuff holding it on at the back but how do you remove the frame from the car itself ? Can anyone point me at an idiots guide ?..or even fancy giving me a hand 😁
Jam03
Surrey
2.2i
I’d offer to help, but I presume you actually want it to work after…
hard top
Dutch Zeds
Netherlands
This link might be of some help :-
AntStark
Hampshire
2002 3.0 Sport
Thanks..that helps a little. I really need to know where it unbolts from. I appreciate it may be obvious once I start doing it
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
From what I remember when I changed mine - aside from the setscrews holding the frame to the bulkhead at the back, there are 3 setscrews (10mm I think) on each side, 2 on the horizontal at the base of the frame and 1 on the vertical plane about 300mm up. The hardest bit is removing the plastic covers in the gap between bodywork and frame, you will have to loosen some trim to get these out. You wii also have to disconnect the hydraulic ram and micro switch if fitted.
