Z3 Roadster M Package
Roads_Scholar
Can anybody tell me more (or anything at all) about the Z3 M Package? My 2001 was produced in Germany and has M badges on the rear of the car below the trunk lip, left side. I has a leather steering wheel with an M badge and a shifter with the M badge. Its a 3.0 convertible 5speed manual. Ive been told, word of mouth, there were a limited number of Roadsters with some M upgrades, but I cannot document this. Any info or link that provide info as to what exactly and M package is and production numbers is appreciated. My Roadie doesn't seem particularly special in any way, but its my first so i don't have any point of reference.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Hi. Your car is a 3.0 ( most likely a sport model).
The Z3M was a different beast altogether with a 3.2 engine and obvious differences such as interior, dials, wheels, and most noted the boot (truck) lid is different.
The M badges on yours are just small additions for appearance. My 2.8 has a steering wheel with the M logo on it also.
Ianmc
New Forest
Z3 (M44)
My sons 2003 E46 318i touring had a M badge on the steering wheel and gear knob (factory fitted). This is about when BMW started to devalue the M brand which they have totally managed to do now, supported by the aftermarket suppliers. I suspect your trunk badge is an aftermarket addition on the Z3, but BMW now put the badge externally on many models.
Roads_Scholar
Thanks for the info. Good stuff. I found the window sticker which mostly confirms the information provided by you fine folks. I don't see it on the sticker, but when I checked the VIN it indicated " Shorter Final Drive Ratio " and " Differential 25% Lock" as options. Can anyone give a brief explanation of these options? S204 and S209. Thanks as always. /
Roads_Scholar
mwpe
Camberley
Redcon1
Glenville, PA USA
'00 Z3 2.3 Roadster
I'm sure you noticed your sticker shows the production point as Spartanburg, SC, not Germany.
Nice car, I don't see a lot of that color.
Roads_Scholar
Yes. I was mistakenly looking at the engine transmission info.
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
Hi, all the Z3 cars were made in Spartanburg, SC USA. The ///M external badge stuff was just put on by another owner, this is common. Some people even go so far as to change out the side gills, front bumper, weld in another exhaust outlet [the ///M has 2 double tail pipes out] and a variety of other things.
There were options to have other bits and pieces as options such as the ///M steering wheel and shifter from factory. This does not make it a ///M which has a worked motor and a variety of other envious additions, some mentioned above.
You are likely to have the ///M sport suspension which is about 1 inch lower with a slightly thicker rear sway bar. I have that option, and maybe you even have sports heated seats as well.
So, sounds like you have a 3.0 with some options and a bunch of ///M badges added because someone though it would be cool.
Cheers.
Roads_Scholar
Cheers and thanks for you fine comment. I dont think I have a bunch of m badges out in by anybody but BMW. I know the previous owner and he did not replace the steering wheel or shifter or put the m on the left side of the tail end. Thank you for your condescending hypothesis, however. Additionally, it serves now purpose to let me know what I might have, but you DO have, except to highlight your vehicle.
No doubt you have more Z3 knowledge than I, but I am trying to learn.
In the future you may want to answer questions, if you wish, but keep your assumptions to yourself
Roads_Scholar
I still dont know what the 25% differential lock means. Any info on that would be appreciated.
Grumps
Z4 e85 2.5i
Wow! You asked and you were given a perfectly acceptable answer. If you don't like answers please don't ask questions.
Roads_Scholar
It's not a matter of not liking the answer. The answer was wrong, off topic and inappropriately condescending.
Grumps
Z4 e85 2.5i
Ok. Right your car is by no means any sort of 'M'. It is a 3.0 standard spec or sport. The gear lever and steering wheel could have been options at new. The external badges have been added by someone at some point in the cars life. That is the on topic correct answer to your question. I do hope you didn't find my answer condescending.
Roads_Scholar
Thank you. That's all I was looking for in order to learn. I appreciate that.
Cooper
Australian Zeds
3.0i 2001
The 25% is the limited slip diff, you have that installed. You can google how they work and there is a some youtube vids on it if you want to see the mechanism. It might be worth changing the oil in that if you have done more than 100,000 miles.
BTW, I reread my reply to which you accused me of being condescending. I was not rude in any way. No offence was given but much was taken... as the saying goes.
Cheers.
