Will_460cs
- Joined
- May 14, 2016
- Points
- 29
Heres is an example of rust repair I'm currently doing to my dads/GF's new car... a near immaculate 2001 Z3 MSport, the process is good example which may aid someones DIY.
All good except some pretty nasty looking rust on the structural sill of Z3 behind the near side passenger front wheel:
First stage strip stuff as I need the outer sill out the way, which means:
Remove Wheel
Remove the plastic Undershield
Front Wing removed
Remove Plastic Jacking point
Door Sill plate removed
Detach but not remove the outer sill (to save time)
Then to stage 2:
Using a Angle grinder 115MM with a selection of wire brush's (no flap wheels or grinder dies as I want to preserve the good metal)
So now the rust is removed and the metal has a polished look to it, luckily the panel isn't perforated as the rust is only on the outside. The rust has has been caused due to break down of the under-seal BMW applied and is no doubt cased by debris coming of the tyres..
Next step Kill the remaining rust and stablilizess the metal, this is the step that stops rust reoccurring. This time I used Krust, but have used Finegans 21 and load of other stuff that looks the same i.e. a milky white thin liquid that turn the metal black. (basically its an acid +other chemical chemicals)
I like to leave this for 24hrs and then wipe down with Panel Wipe, then Next step:
Apply a Zinc Based primed, in this case a brushed on version of Davids 182 Zinc
Then after curing for 12hrs the next stage:
New underseal/stone chip (i used gravtex with a proper schutz gun), of course after carefull back masking of the area:
Next step will be paint... Ill be doing that next week sometime...
Remove Wheel
Front Wing removed
Then to stage 2:
