Hi all, has anyone ever removed the inner wing liner? Any tips gratefully received.
They are tight but should not be that bad - start from the front and work along inner edge and that should move and you can then twist it out. A possibility is that a previous owner has undersealed them in - try running a flat blade under the edge to break bond.Removed all the screws, but liner would not budge, absolutely solid in place.........
I'll try that.Should be four screws in total @ZTec two in the wing and one at the bottom of each side. I found pulling it down from the inner side behind the shock helped dislodge it.
