Z3 Rear drive shafts
Dakar Z3
Dakar
Sunderland
Z3 2.2 , Z4 Coupe 3.0si Auto
Can anyone advise the difference between wide body 3.0ltr drive shafts and Wide body 2.2 drive shafts.
Are the flanges the same size etc ?
Dakar
In short No.
My parts comparison matrix which has information sourced from RealOEM shows:
2.2 small case diff flanges with LK=103 mm and M10 bolts
2.2 Medium case LSD diff flanges with LK=86 mm and M10 bolts
3.0L medium case diff either open or LSD flanges with LK=94 mm and M10 bolts.
Not sure it LK= the flange diameter or the bolt hole radius?
The 3.0L half shaft shows a 110mm diameter flange.
If your car has a medium sized diff, you can change the flanges as needed. They pop in and out easily.
In short No.
Hello Murray,
I hope you are well,
Thank you for the info, much appreciated
have you fit the new brakes or are you keeping them for a rainy day 😃
Best Regards
john
Dakar
Saving them for a rainy day. Its summer here so out driving around lots.
