Z3 Headlight Upgrade
bertiejaffa
Manchester
Z3M
HI all, ok this may have been debated before but I thought I would ask for opinions anyway…. Before I start, I know that UK MOT is an issue and I will make sure that they don’t dazzle people etc…. My lenses are perfectly clean too and I have 20/20 vision :D
Ok so, my old M used to have upgraded Xenon headlights that had been professionally fitted before I bought it and they were fabulous in the dark. Last night whilst driving home from the Scottish run I realised that the 23 year old candles on my new M just don’t cut the mustard, in fact I would go as far to say that they make driving at night dangerous as I couldn’t see more than 1 car ahead of me whilst on the motorway.
So I am looking for any thoughts on the best Xenon upgrade for the standard lights. I know you can buy the smaller halo projectors but I want to retain the standard headlight but fit bulbs and upgrade that actually shine the road in front of me.
Cheers
From an official point of view Lee it is now an mot fail to convert a halogen headlight to hid or led you could pass a replacement light unit if it designed to take hid or led from new.
Stephen.
bertiejaffa
Manchester
Z3M
lol - thanks Stephen, I know that it is an issue but thankfully I have a way round that the same as I do with the opposite end of the car where the noise & polution comes out :whistle:
in the meantime I think I have found the right ones.... just waiting for a second call back from the company...
Dipped: https://www.autobulbsdirect.co.uk/hb4-9006-hids4u-stealth-55w-xenon-hid-conversion-kit.html
Main Beam: https://www.autobulbsdirect.co.uk/hb3-9005-hids4u-stealth-55w-xenon-hid-conversion-kit.html
Any thoughts?
Osram night breaker bulbs would be my choice. In the Z3 and the E85 Z4.
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
These `Osram night breaker bulbs` ... are they just plug and play?
One problem Lee, the Z3 has pattern lens, wont these interfere with the light pattern from the new bulbs or vice versa? I thought these were to be used with clear lens and flat reflectors?
Yes Colin, they’re the ones. A good upgrade.
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
I bought them but they won't go in my 1999 Z3, as its my case the bulb has a plastic fitting kit attached to it, which is not detachable.
jonco
Chester
'98 1.9 Auto
Thanks for info - I was about to order but will now check whether they will fit '98. They did come up as compatible when I put my reg no in.
You need to buy the Night Breaker in the right style of bulb. H7 won't fit.
jonco
Chester
'98 1.9 Auto
I'll bow to your experience Tony but it's confusing.
realoem says H7 for normal beam(part 06) as do other parts catalogues - do you know which it is?
06Longlife bulb12V 55W H7204/199963217160781$20.90
07BulbHB3 12V 60W263217160785$18.86
If you look it you should be able to see which type is fitted
The hb3 ( main) hb4 (dip) have plastic bases with multi plug
You should be able to see it relatively easy.
Stephen.
jonco
Chester
'98 1.9 Auto
The hb3 ( main) hb4 (dip) have plastic bases with multi plug ..........................
Stephen.
Thanks Stephen - will have a look tomorrow.
This is what an H7 bulb looks like Colin.
GreenFish
Just to say that I fitted the Osram Nigh Breaker bulbs yesterday. Made a big difference as could hardly see a thing with the previous bulbs. They were "Sylvania" - not a name I'm familiar with to be honest! The main difference for me is how far they reach
Fitting was a pain though. Had to do it outside it the dark as had a trip to do today and needed them for that (too dangerous last time I did it with the previous bulbs).
Went for the headlight removal option. The drivers side was "okay" - I removed the indicator connector and then the headlamp bulb connector before removing the bulb. Passenger side was a PITA - the indicator wire was so short I could only move the headlight a few milimeters out to remove and the overall fitment seemed more hard work.
That screw deep down in the panel is a pain on both sides. Luckily I watched a YouTube video beforehand and purchased a magnetic pick up pen - this was needed! To screw back in, I put a small piece of masking tape inside the socket to hold the screw. Amazingly it worked. Took me 2 hours all in....mainly due to my (lack of) skill level :)
