Z3 Fuel Gauge
Harryd
South Warwickshire
Mine is intermittent. Before I start taking things apart, is it likely to be the gauge or the sender? I had wondered whether the gauge itself was mounted on some sort of circuit board, as it possibly comes on or goes off when I press the trip reset button.
Thank you in advance for any insights.
Fuel sender is most likely. It's accessed behind the drivers seat, you'll need to cut the carpet (it's marked out where to do the cuts).
There is an article on here somehwere that covers the procedure.
If your fuel gauge hasn't been "reading" silly levels I would check the gauge first, easy job to remove them.
Harryd
South Warwickshire
Thank you all very much. I shall explore the Knowledgebase further, before I ask any more questions. It does seem very useful.
