Bigwinn
Evening
Looking for advice (usual comfort zone of Z4 M54 goodness is being abandoned) about how to change an engine on a Z3 M52 2.8
I've done engine changes before on E30's, but I wanted to check from those in the know...
Assume its doable from the top with an engine crane, bonnet off? its a like for like swap
Usual list of things to remove/disconnect:
Cooling
Electricals
PAS
Other ancillaries
Fuel lines
Exhaust
Best to disconnect the prop shaft and take the gearbox out with the engine
Advice on manifolds etc- usually do these off the car
As you can tell its been a while...
I'm all ears!
Stuart
Cooling
Electricals
PAS
Other ancillaries
Fuel lines
Exhaust
I'm all ears!
Stuart
