dimiras
Hello,
Im thinking about upgrading the stabilizer bars on my 4 cylinder Z3, right now I have 22.5mm at the front and 14mm at the rear.
I checked RealOem and the M Sport package for my car has 23.5mm at the front and the same 14mm at the rear.
As you know at the front we can use any e36 bar and in my country there are plenty of e36, the compacts that have 24mm for the 318tds and 23,5mm for the 316i. I also found that the e36 318tds touring has a 25.5mm that is also used on the Z3 Roadster M54 3.0 M Sports suspension and I found one very cheap.
Do you guys thing that 25.5mm would be too much without upgrading the rear one? or should I just stick with 24mm or 23.5mm?
Another option would be to upgrade the rear one to 15mm or 16mm which one do you think would work good using the 25.5mm?
Thanks
Thanks
