For sale
A front brake kit from a Z3 3.0, will fit Zeds from 1.9 to 3.0i, included in the kit is the following: -
The discs, calipers etc. have been off the car for a while and have a little surface rust on them, I have cleaned up one disc so that you can see what you are buying. A bit of emery paper and wire wool and they will be as good as new.
£200.00 plus postage.
- 2no: 300 x 22mm Vented Front Brake Discs (virtually new)
- 2no: Brake Calipers
- 2no: Caliper Brackets
- 1 set of Pagid Brake pads (virtually new)
- Caliper Pins and braket bolts
