I've decided to change the engine coolant on my Z3 3.0.M54
Been looking at a few generic videos of the same engine on a few other BMW models
Couple of questions
How accessible is the engine drain block plug.. I cannot seem to see it poking my head under the bonnet.. Does it need to be removed from underneath the car.. If so I guess it's a pit or axle stand job (where do you put the axle stands if so).. Is it a hex plug or bolt?
Is bleeding relatively straightforward.. I see a bleed screw on the expansion container.. Anywhere else??
I'm going to flush it and use an approved BMW coolant
Many thanks
Couple of questions
Many thanks
