Found Z3. 3.0 Half Shaft
pgunter
Winchester
2.2i Sport Zedshed Special
Help ....
Need asap a 3.0 half shaft, that's the differential to the wheel. They are not handed so either will do. After a little bit of struggling with the Z3 in the shed, we came across an issue where the CV joint seems to have seized. It is unfortunately unique to the 3.0.
If anybody happens to know of one being broken or of a company who can replace the said cv joint. It would be much appreciated. As soon as you mention BMW half shaft, they start laughing. BMW do not have any stock either.
Hope someone can help.
@Brian H thoughts ?
pgunter
Winchester
Thanks @Nodzed Its annoying as soon as you mention 3.0 Z3... you can hear the sharp intake of breath.... lol..
Thanks @Nodzed Its annoying as soon as you mention 3.0 Z3... you can hear the sharp intake of breath.... lol..[/QUOT
You dont need to tell me mate I have an M remember buying parts is not funny :( Hope you find the part
pgunter
Winchester
Spoke to the guy in BMW... you could almost hear him laughing as he was reading the screen back to me..
pgunter
Winchester
Thats what makes this forum. Helpful people.. and always good.
Every time I have changed a rear wheel bearing on a BMW it has been seized solid in the drive flange some I've managed to press out, others not. Those which did press out needed the splines cleaning with a triangular file before they would go back together.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Those which did press outer needed the splines cleaning with a triangular file before they would go back together.
Exactly this, I has a mare of a job putting mine back together, I ended up dressing the end of the spline and bingo it went back together,
  • Like
Reactions: Lee
pgunter
Winchester
The first went in fine. The second was the issue. @Lee @GazHyde will agree I am sure.
  • Like
Reactions: Lee
pgunter
Winchester
@Brian H Is a star... Part sourced and looking forward to getting 'Fi' back to full health soon. She's also getting a rear beam and diff bush overhaul at the same time.
