Hi, my new to me 2000 3.0 Z3 has become undrivable. Driving along and the EML, DSC and ABS lights will come on, the engine revs will start to faulter and then after a few seconds the lights will go out, the engine goes back to normal and away we go. A little further on and it will do it again. Sometimes, the engine light will also come on and then the engine cuts out. Will refuse to start again until I take out the key, leave it a few seconds and then try again.
Other intermittent items to note,
- something when I press the brake pedal the ABS will kick in for no reason. This is when I first set off and coming to the give way at the end of the road, still in first gear. Doesn't do it all the time, just now and again.
- somtimes, will not start, tries to start but nothing. Will start if I leave it for a few seconds and then try again
- after driving for a few miles, when I stop the car, the amber oil light comes on. This indicates low oil but the oil is in the middle of the dip stick when checked. I presume a faulty oil level sensor. Doesn't do it every time I stop the car.
So far, have changed the crank shaft sensor, to see if this would cure the car not starting.
I think that I have a dodgy oil level sensor and somewhere a wheel sensor, but which one.
The local garage diagnostics are not picking anything up apart from a dodgy pre-heater O2 sensor on Bank 2 (why does it always seem to be Bank 2?) but they say they don't know which sensor this is on the car to change it.
