z3 2.8tu abs and tc light on
look595ultra
the traction control and abs light came on the other day and has stayed on
i do have a cheap obd II scanner which works under dash
i have adapter for under bonnet but when i plug it in it won,t communicate
is it my scanner ? its a kingbolen ebay cheapie
any ideas on either issue much appreciated
Try spraying the under bonnet connector pins with electrical contact cleaner. I often need to do this to get a connection with my code reader (Foxwell nt530). BTW the under dash socket only reads engine and auto trans modules, nothing else.
You are going to need a scanner with BMW software to read the ABS module. Connect to the under bonnet/hood socket.
A Foxwell NT530 with BMW software and 20 pin to ODB adapter will do it.
There is also a range of Creator scanners that are BMW specific.
If you have an old windows computer, you can set up INPA: https://www.bimmerforums.com/forum/...tions-Experiences-Discussions-Experimentation
Once you get the codes, post the code and the description here and we can help.
OBD rule #1 - Delete all of the codes that you see upon first connection. With luck, most of them will be transient. Only note the ones that come up again when you reconnect as they will be "solid".
thank you for all your replys
have ordered a creator bmw scanner
hopefully have more of an idea then
