Newtricks
Z3 2.8 build month June 1999, registered March 2000. I believe EWS3D
This started a couple of weeks ago when I returned from taking it in for a pre-MOT check - parked up, moved a couple of cars to be able to get the Z3 by the garage, got back in the Z3 and the key just clicked - absolutely nothing, no crank. The car had been faultless going to and coming back from the garage (c 35 mile round trip). I had other work to do in preparation for the MOT, so I’ve been pressing on with that including refurbed starter motor and various vacuum hoses. I managed to lead myself to believe that the starter motor could be culprit (no such luck).
Still got a non-starting Z3. I’ve read a number of threads @mrscalex proving very detailed and in depth - I’m way out of mine….
I don’t know how to start diagnosing this current problem. The battery has plenty of charge.
Is there a quick way to determine where the problem is? Is bypassing EWS a possibility to see if that is the cause (I don’t want to delete it, I’d rather fix It).
Any assistance/advice gratefully received.
