Hi, can anyone tell me if swapping throttle bodies is simply that, swap it and drive away or is there some setup or 'pairing' to be done?
Also is the rubber 'O' ring sufficient to prevent air leaks or is there another seal / gasket to be used when fitting the new throttle body. The mating surfaces are flat and clean but I can't see how the 'O' ring fits in such a way that it prevents any leaks.
Thanks.
Thanks.
