Yet more battery questions
Discussion in 'Z3 Roadster & Coupé' started by brilie, Feb 27, 2012.
  1. brilie
    brilie Zorg Guru (III)
    968
    654
    148
    doncaster
    Model of Z:
    2.8 roadster
    Hi, Sorry for the old topic but I had to share my joy!!!!!
    Old story flat battery,charge it up starts OK,
    Week later flat battery charge it up starts OK,
    Couple of days later flat battery bought ctek charger leave it for 24 hours battery flat!
    Now for the good bit ,took it back to shop 16 months old bosche battery,the man from
    the shop was amazed when he tested battery and confirmed it was knackered!!
    Under guarantee no quibble NEW BATTERY of the shelf straight away(there is a god)
    And now my new problem,
    Do I put the new battery on charge????
    My charger is a ctekmxs 3.6
    many thanks
  2. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    If you drive your Zed daily then obviously no need but if it is in the garage between outings then YES put it on charge. The Ctek chargers are designed to be left permanently connected to a battery to keep it in tiptop condition and will prolong the life of your battery substantially.
  3. brilie
    968
    654
    148
    doncaster
    Model of Z:
    2.8 roadster
    Thanks for the advice,I was unsure with it being a new one,I didnt want to kill it.I shall put it on charge
    and hope for a long life
    Thanks again
  4. Boysie
    Boysie Zorg Guru (I)
    Supporter British Zeds M Power
    Dec 6, 2011
    1,294
    190
    94
    West Chiltington, West Sussex
    Model of Z:
    M Roadster S50
    Ctek are the best
    Out of habit, I just put mine on charge as soon i put it away
    You are not the first person i have heard of who bought a duff battery recently
    Do you have the cigarette lighter adaptor
  5. brilie
    968
    654
    148
    doncaster
    Model of Z:
    2.8 roadster
    No I havent, it is hooked up under the bonnet as I type!!!.If I am going to use it as you say the cigarette lighter plug sounds a good idea.
    How long does the charging take before it goes into trickle mode??
  6. Boysie
    Dec 6, 2011
    1,294
    190
    94
    Model of Z:
    M Roadster S50
    Never really looked at the charger working
    But it conditions, does diagnostic check, charges then trickle
    i believe in that order :-s
    i did read somewhere that it drains the battery to check something
    'not sure about that though'
    When you get the cig adaptor make sure you push it home
    the charger will have a hissy fit otherwise
    Once again a great charger
    :D :D
  7. brilie
    968
    654
    148
    doncaster
    Model of Z:
    2.8 roadster
    Thanks for all info,cigarette lighter plug ordered waiting delivery.
    charger now showing fully charged and in maintenance mode :-bd
    Cheers Brian
Share This Page
