Simon Blythe
Has anyone used it - thought I might run a can through my system.
Its more just for peace of mind mate, although when dipping the clutch when coming from speed she has cut out a couple of times.Don't see why not, although not sure how much of a difference it would make!
Am I right in thinking just unscrewing the connector means it does "something" which means the system resets somehow or am I imagining it?Depends on the year, and that isn't an exact way to find out either. Most likely read the codes from the round connector under the bonnet on yours.
Thanks for that mate, I'll check them laterNo, you just unscrew the cap and plug the code reader in. The reader will allow you to reset the codes to see if they persist or not.
