Wishbone Bushes
ZTec
Llantwit Major
I need to replace the wishbone bushes on my 1.9 97 Zed, should I go for OEM or powerflex?:)
Personally don't see why you wouldn't fit OEM. I used OE quality stuff when refurbishing the rear subframe on my 2.2.
ZTec
Llantwit Major
Been reviewing OEM against poly bushes, not planning to throw it around or go on the track or anything, just heard that poly was better, I suppose if OEM will last me another 17 years that's the way to go?
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
I'm on the understanding these are prone to go on the Z3? If there's an upgrade option available I'd be tempted to go with that. :):mad:
Brian H
Killin
E36/7 3.0i - E85 Z4///M
.............not planning to throw it around or go on the track or anything, just heard that poly was better.
Stick with OEM if this is the case.
You said it yourself. These, chances are, will be the original bushes. Do you plan to keep the car for 17 years? So what's wrong with the OEM ? Unless you plan to track the car in any way stick with original.
paul.s
thinking of changing these on our z4 as the front wheels have slight front to back free movement . am I correct in thinking these can be fitted without removing the wishbone just unbolt from the floor remove and replace and bolt back up
ZTec
Llantwit Major
That's right on the Z3, just unbolt the carrier and the back end of the wishbone drops down apparently, but it may be a bit of a job removing it whilst under the car unless you have a car lift.
If you want to do that, you'll have to knock them off or alternatively use an air chisel/punch. Rubber grease is a big help in reinstalling the new bush mounts onto the arm.
ZTec
Llantwit Major
Definitely, easier to do off the car.
ZTec
Llantwit Major
I have an air chisel at work. no lift tho just jacks and axle stands
That'll do the trick. I'm going to replace the wishbones complete with both ball joints and sway bar bushes and drop links at the same time, and I'll see what the track rod ends are like. Do it all in one hit.
Aceman
Moderator
Wakefield
///M Roadster
Poly bushes certainly sharpen up the turn in on the steering but they do transmit a little harshness back through into the cabin which you perceive as though you can feel the texture of the road more particularly on rough Tarmac or concrete. One option is to fit Z3M bushes which are made of solid rubber so have a little give in them but less than a standard Z3 bushes so increasing the steering response but not making it feel too harsh. Don't make the mistake though of getting the eccentric ones which they fitted to the e36 M3 but get the concentric ones with the hole centred in the middle.
ZTec
Llantwit Major
Great, thanks for the heads up:thumbsup:
My boss replaced the front lower arm rear bushes on his wife's Fabia using the solid ones fron a Seat Cupra and now the car is absolutely horrid to drive so they're coming off. This is front wheel drive though.
ZTec
Llantwit Major
Looking at the Z3M bushes, I suppose it's a happy medium being between the standard bushes and the poly ones.
Dickymint
Somerset
Z3 2.2i Sport
anyone done this and have the correct part numbers for the M spec ones?
cheers :)
Not that I'm overly lazy but last time I looked at pipework the part number from bmw was wrong :p
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
If I remember the numbers are in Mike Fishwick's tech article so check that out. Even if the numbers aren't there it's a great read! JIM
TaffZee
Near Llangollen North Wales
Z4 3.0 SE
I would go for the upgraded Poly Bushes, tram lining has always been a major issue with the Z3, and replacing the standard bushes (although doing this did not eliminate all the tramlining it did vastly improve it) I have not noticed any difference in ride comfort with the Poly bushes, after all ride comfort is nothing to do with the bushing you use but with the suspension set up unless you have excessive movement within that part, the movement or lack of it when Poly Bushing is used is nothing to do with a harsh ride, and would not show any drop in ride comfort that could be noticed, this point is a pivot point on the suspension, you may notice that the ride quality becomes a little tighter "which is a good thing". The reason for reported Hard Ride is because you have replaced a worn out part which has allowd excessive movement with a part that stops this happening (OEM or Poly) , and in fact this is how the car should ride.
ZTec
Llantwit Major
Great, thanks, will keep this in mind
