Wiring diagram
Sean d
Messages
8,845
Lincolnshire
Can anyone please direct me towards a wiring diagram for a Z3 thanks
littlefeller
Messages
2,917
evesham
I have a few different ones inc an //M z3 I even have one that focuses on just the ZKE control unit. so if anyone want ;)
Murray Wall
New Zealand Zeds
Messages
713
Timaru, New Zealand
3.0L, 2.0L Roadsters
@Sean d The attached wiring diagram covers Z3's from 4/99 on wards.
If you are researching the 3 wire cruise control switch matter, you'll see in these diagrams that a three wire hall-effect switch is used to give a signal to the DME (6571.0-3). The issue is that the early M52TU powered Z3's got fitted with a 2 wire switch before the 4/99 mods got through to the factory floor. The 2 wire switch gives the DME a signal that was opposite to what was needed e.g. It said the clutch was in when it was actually out, so the cruise control would not turn on and hold speed.
billz
Messages
6,580
Langley Mill
I have been trying to find one for the Z4 but as of yet not found one
Brian H
Messages
3,629
Killin
E36/7 3.0i - E85 Z4///M
Edit.. Thought I'd found the Z4 ETM, turned out to be owner manuals
Brian H
Messages
3,629
Killin
Is that not just the Owners Manual tho Brian. I am after the actual wiring diagram
Just edited my original post, too hasty this morning :)
gookah
Messages
2,960
Shropshire
2.8 Z3
you have to run java,
my first screen on opening that links shows this below:
should be a link in left hand side to click on and run java, which then opens the drop-downs on the LHS in a blue colour. then I can select any diagram.
