Winter Hibernation
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Good luck with your 1st hibernation :p
It's my 1st hibernation time too ;)
But with my tortoise :)
Scary time ( next week ) :(
Antm72
South Yorkshire
A good fitting full cover is good but which ever one you use the fit is important and a very clean car as any wind causes them to rub and damage paint.
If electric is on hand a smart charger connected in the boot will keep the battery in good condition....
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
I just take the positive battery terminal off and forget about it. Go back in March and it has always started first time. I have a carport but but no longer use a cover as it did start to rub the paint. If your happy to pay out good money for one I think you should be OK. I was talking to @Bozzy about his and he's very happy with it.
Bozzy
Long Eaton.
:wideyed:
Yes I am very happy with my outdoor covers,got a half cover made by Cabrio shield (I think) and a full cover but can't remember the make,It's multi layered and breathable,not cheap though at £130 :wideyed: But the alternative is leaving my zed open to the elements as I don't have a garage\car port.
Steve
Gundun
Belgian Zeds
West Flanders
2.2i Sport Line Individual
I'll tell you what I'll do:
1. Inflate tyres up to 3 bar (43psi)
2. Hook up a battery charger: I have the CTEK mxs 5.0 with a very convenient quick plugin cable (so I don't have to fiddle with clamps and be afraid of shorts)
3. Get yourself a nice breathable cover, remove aerial before putting it on
4. Once covered, leave a the windows a few mm down to help ventilation (gets moist out, so you don't get mold in the car overtime) and don't keep the rubber window seals compressed for a long time eventually deforming them.
Alan W
Bexley, Kent
Z4 Coupe E86 3.0 si
My winter storage schedule:
Clean car
Flush and drain engine oil, add new oil and fit new oil filter (that way there are no nasties left in the engine)
Apply gummi phledge to all the roof seals
Apply leather cleaner and conditioner to seats
Keep windows closed but put a caravan condensation trap thing in passenger footwell
Connect a very low charge trickle charger to battery and cover car with an indoor breathable full cover
Start car every couple of months and run until fully warmed up (keeps fuel pump working) and in my case I pull the car out of garage into street, turn it around and put it back which rotates the tyres
I also have a list of little jobs which I will do if there are any nice dry days
Then just look forward to the first sunny days of spring!
Tracy Dee
Hertfordshire
For any lenght of time using a car over outside use a soft fleece cover first the a second outdoor cover over the top to avoid paint marking.
Mine will be used 2 or 3 times a week so a cover is a pain getting on and off it will spend as always the winter outside in the street.
Gundun
Belgian Zeds
West Flanders
Not knowing much about tortoises I am really curious on how this works out...does she know she's supposed to go to bed next week or...did she notify that to you in advance so you can prepare yourself if you don't see her around for a while...will you just leave her somewhere nice & cozy hoping she will get the message and just go to sleep...?o_O:)
Low Rider
This is what I use
1 in the boot OFS well and
1 in the map holder
Is way if the car needs to be moved neither of them will spill over and at 69p each you can throw them away once they've done the job
N
N4LLY
Guest
Thanks guys and gals, getting the idea/mental picture of what's going to be required.
Have a good spot to park it, well sheltered from wind.
No electric supply though for a trickle charge to battery.
Would like to think that i would keep taking out on dry crisp days, but once moth balled i
fear i might get lazy and leave standing.
So if i prep by removing battery, a good half and full cover, dehumidifiers for cabin and boot.
A good heavy duty charger/jump starter and tyre infiltrator.
It should not be too difficult to take out every other week or so, or a worry if i leave a few month's.
Most excellent input, thanks again.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
Fit hardtop and winter wheels and keep it on the road :racecar: hardtop comes off on the nice days though.
Only because its my only car, if I had another run around I would probably use that but I'd still want to use the zed on nice days.
Devon Z
Brixham, Devon
99 2.0 Individual
Mines sorn'd, not much prep, take the 18" off as I'm repolishing them over the winter got original 17"s for her to stand on, release the hood and drop the windows to take pressure off the seals, two dovet's then a car cover.
If I can make enough room in my garage I may put her on axle stands and give her a clean underneath/check the sills etc.
My winter ride 98 Volvo V70 R with Rica 310 chip and various other mods, owned since 2007, The turbo fidge mover;)
roadvoyager1
Shotley Bridge
2.8ltr
AS other have said clean and put battery on charge. I use a C-tek MX5. Only other item to add is inflate tyres to 40 psi to reduce the sidewall becoming damaged.
N
N4LLY
Guest
release the hood and drop the windows to take pressure off the seals, two duvet's then a car cover.
Windows and roof released Hmm interesting.
Ah ! Duvet's, sounds a good idea. I have one that needs replacing.
Hhhhhm new duvet for the winter, nice, snug :)
How many Togs do you suggest for a Zed ? =))
Devon Z
Brixham, Devon
99 2.0 Individual
All depends how cold you think she may get?;)
