Don't suppose anyone has any tips for removing the wing badges on the E89 - have done a few searches but drawn a blank?
Bloody marvellous Tony will take a look tomorrow and yes I meant the badge rather than the indicator.You mean badge or indicator light Garrie?
Tony I can see the two retaining pins that you highlighted which hold the badge on but I can't work out how I could get to them to secure the replacement badges. The back of the wing nearest the driver and passenger door is blocked by what looks like sound deadening foam. How did you manage it? CheersYou mean badge or indicator light Garrie?
Oh OK thanks.When you remove the badge the pins pull out of two plastic inserts, they are what hold the badge in place.
Much the same, the badge needs to be prised out, preferably without damaging the paintwork. I put masking tape around the edge and used two plastic trim tools to pull as level as possible. Came out OK without damage, but care is needed.How’s this done in a Z3 guys?
Worked for me many times, just have to be gentle.Nylon fishing line is no good.
And, having seen it done last Saturday you now know it works.That's why the old credit card.
I’ll be trying it out shortly ..does that work for the bonnet one ?And, having seen it done last Saturday you now know it works.
