Found windscreen washer nozzle and filter
ibart
rugby
Z3 3.0
Hi, I'm after a single or pair of windscreen nozzles and I'm assuming check valve (see photo).
Just failed it's MOT due to, in part, the drivers side nozzles not delivering sufficient flow, I've checked the pump and cleaned out the reservoir and got flow to the pipe prior to the nozzle also the nozzles are clear so I'm assuming a sticking check valve is probably to blame.
mwpe
Camberley
Those nozzles are a common problem, you should be able to get them from a main dealer.
ibart
rugby
Z3 3.0
had to change the pump and valves all sorted now.
