So for today's job I thought I'd get the windscreen washer nozzles sorted - one didn't fit correctly and had become loose and the other seemed to be leaking.
Anyway I'd ordered 2 new jets before Christmas and picked them up from Sytner yesterday (£22).
So I removed the bonnet insulation and found that both the return valves were blocked and had been leaking under the insulation. Tried to remedy the issue but found once separated the valves cannot be reassembled so I now need to order 2 of those.
In the interim I fitted the nozzles and reassembled the supply hose - so from the outside everything looks great but underneath its the same as it was before I started minus a return valve and the insulation.
So yet another rollover job and I'm hoping the hose clamp doesn't break when I remove the other valve. I'm assuming the other valve fits straight into the support bracket that remains without need of a clamp as before but I can't tell from real OEM if this is correct or just the way somebody decided to do it last time. The diagram provides an overview of the parts but not how they should be fitted together.
