Paul Newton-Smith
- Joined
- Sep 29, 2016
- Points
- 49
Stupid question… Is there one or two check valves are under the bonnet for the washer system?
Thanks Tony. The pump itself seems fine. I just have water coming out of the hole on the side of the check valve.I seem to remember that there is one on each washer jet maybe?
ps. If you need a new pump I have one you can buy.
Good idea. That will hopefully get me through the MOT. Not sure the replacement parts will arrive in time.As a temporary measure you can replace the check valve with a couple of inches of metal brake pipe.
