window problem
allan
bradwell
z4 2.2i se
another problem before now when i put the roof down hold down the roof button windows will lower roof gos down windows close, now both windows go down but only the passengers window gos up driver side stays down any ideas
If your windows aren't behaving correctly try this to reset them... (hopefully!)
1> Turn the ignition on
2> Push the open window button until the window is open, then keep it presses for 5 seconds longer.
3> Push the close window button until it is closed, then release.
4> This should reset the memory on the window.
Repeat the same procedure for both windows.
allan
bradwell
z4 2.2i se
hi mark yes it is with key we always use
thanx gary will give it a try
allan
bradwell
z4 2.2i se
hi gary, tryed resetting the window but no joy any other ideas
B
badman gee
Guest
have you tried the z4 forum?
might get more info there?
:D
allan
bradwell
z4 2.2i se
hi mark i think thats a good idea will give it a try
Thats where I got the reset procedure from in the first place, although it is documented elsewhere too...
Borrowed this section from http://www.zpost.com/forums/showthread.php?t=62834
Initialization is performed on the power window switch of the relevant door.
Requirements for correct initialization:
• Initialization with engine running
• Convertible top, doors and windows closed
Initialization comprises:
• Erasure of initialization
• Reinitialization
An initialization must be performed:
• In the event of malfunctions, e.g. no one-touch control function, no opening or if available no comfort function is possible
• After the power window drive has been replaced
• After work is carried out on the power window mechanism
• After a power supply interruption, e.g. disconnection of the battery or disconnection of the power supply to the door
• After the door window glass has been removed and installed or replaced
• After adjustment work on the door window glass
• After adjustment work on the convertible top
• After replacement of seals
Erasure of initialization:
• Open door window glass fully
• Operate power window switch in "Open" position four times within 10 seconds
This erases initialization of the power window, anti-trapping protection and toll function are inactive.
Check whether one-touch control (toll) function is inactive, otherwise repeat procedure.
Reinitialization:
Avoid a break between the two steps!
• Operate and hold power window switch in "Close" position (second switch stage)
• Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer
allan
bradwell
z4 2.2i se
well the window is sorted i tryed window down hold and window up hold well i tryed everything but i just read on the net that when you do the reset you must open and close the door after you pull the key out so out i went and amazing it worked
many thanx to gary for all your help
