Window leaves gap when door closed
Nothgiel
I have an intermittent problem where the window does not always go up and seal instead it seems to sit away from the seal leaving a gap, do you have any ideas what this might be? :(
philiper
East Anglia
E86 Montego Blue Auto
have you tried resetting the windows to see if that helps? if not, worth a try (copied from another source)
- Sit in the car, and put the key in position 1, so you have power to the windows.
- Push and hold down the window switch, and keep it held down for 5 seconds after the window is all the way down. This re-sets the memory, telling the motor, in effect, "Remember where we are now? "
- Roll window back up, and release switch.
- Open door. Marvel at the downward motion of the window. Repeat on other side, if needed.
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
I never knew that. :)
benf
Leicestershire
Z4 E89
Me neither, must admit it's a strange feature, never did it on my z3, thought there was something wrong at first till I seen someone else's. Something else to go wrong in future :whistle:
philiper
East Anglia
It is a handy thing to know, I have used it on my Z4 when I was replacing the seats and had the battery disconnected! Need another Z4 in my life ;)
