Hi All,
I have made a batch of wind deflectors to suite the Z3 with the black roll hoops.
The wind deflector is a unique shape and style (inspired by Lee). The design allows air to pass over the windscreen and then under the wind deflector. By allowing air to pass under the wind deflector turbulence inside the cabin is significantly reduced.
The design also allows the central storage compartment to be opened and used easily which is a useful space when going for a longer trip.
The deflector is made from 5mm clear Perspex and is very clear.
The Perspex is laser cut, clean and very precise.
The deflector is held in place with wide 35mm Velcro (supplied).
A number of people have preferred the OEM mesh wind deflectors over Perspex due to the turbulence experienced inside the cabin. In my opinion this design is superior in its effectiveness, rearward visibility and by allowing access to the storage box.
Typically other retailers will charge in the region of £100.00 (sometimes +postage)
I am asking £75.00 including postage.
They are also available through www.ZEDonist.com but will be slightly more expensive due to additional costs.
Wind Deflector
Wind Deflector
