Will they fit??
Axelf
Co Durham
Going out to buy a set of MV2s in 18" but will they fit my car??? I have lowered it so will this cause any problems? The tyres on them are 225/35/18
An OEM set of MV2's should fit fine. If genuine they should be a staggered set with 8" 225/40/18 on the front and 8.5" 255/35/18 on the rears.
If they are 225/40/18 all round you either have replicas or a set of four front wheels. If they are reps, then you would need to get the offset value to make sure they are in the correct range.
Don't worry, there are lots of numbers but it's easier than it sounds when written down. Generally E36/E46 3 series wheels are a straight fit, which is why the MVx series are OK.
I've tried to get close ups on the images in the adverts and I can see 255/35/18 tyre size markings on two of the tyres. This means at least 2 of them are rears! It would seem they are a staggered 3 series set. I would suggest a message to the seller and ask him for the exact dimensions of the wheels (stamped on the back) and the tyre sizes fitted to be 100% sure.
One of them is missing an ///M badge though which should be in the little depression by the stud holes.
Axelf
Co Durham
This is what the title says for them
18" genuine mv2 bmw X4 Alloys Wheels 5 3 Series Vw T5 Vauxhall Vivaro traffic
Found the ad easily enough by searching and looking at the pictures. If you do message him I'd ask him how much tread the tyres have too. "Good tyres" isn't a useful unit of measurement :whistle:
Brian4
Near Grantham
Z3 3.0i Auto
Hi @Axelf when you message him make sure you ask whether they were from a 3 or 5 series.
The ones from a 5 series wont fit as the offset is too small and were 8" wide the ones from a 3 series and Z4 were staggered 8" front 8.5" rear
http://felgenkatalog.auto-treff.com/ look for style 135 on page 7
Axelf
Co Durham
No I messaged him for some info and he never got back to me..... Think they no good may be off a 5 series
Axelf
Co Durham
Well he got back to me , they are staggered so off a3 series et of 47 front and 50 rear
Antm72
South Yorkshire
Standard zed offset is et41 so 6mm further in on the front although the wider wheel will make that sit ok. The rear at et 50 you may need 15/20mm rear spacers to fill the arches but they will fit fine :thumbsup:
Axelf
Co Durham
That's good to know at least they will go on as my car is pretty low haha
Antm72
South Yorkshire
Should be fine look forward to the pics :thumbsup: You have the same spring set up as me and i run 8.5 et38 front and 9.5 et 33 rear and they don't catch these will tuck under fine..
2.2 Sport Individual
Very nice - really suit the Z3:thumbsup:
