Will rear light lenses split to clean?
BinJuice
East Devon
Z3 2.2 Sport
Hi all,
After some advise re rear lights and if they will split apart to clean?
Asking as on latest MOT had these advisories. Car is a Z3 2002 clear lights
Repair as soon as possible (minor defects):
  • Nearside Rear reflector defective or damaged by up to 50% of the reflecting surface (4.8.1 (a) (i))
  • Offside Rear reflector defective or damaged by up to 50% of the reflecting surface (4.8.1 (a) (i)
Not damaged but gone black inside.
Is it worth splitting them to clean, or put in a bucket of soapy water or blast with an airline or bite the bullet and buy a set of lamps?
Many thanks Keith
Rudyrov
Phoenix, AZ
2.8 L Roadster
I would be very skeptical of separating the lens of any assembly like a headlight or taillight to clean them. I have done instead soaked such assemblies in a bucket as you mention and used a variety of small brushes to get at the various areas in the past.
I also have an old "water-pick" that I use to direct soapy water in a variety of ways when an area cant be reached by conventional brushes.
bertiejaffa
Manchester
Z3M
The fronts split using a hotair gun or putting them in the oven to melt the butyl in order to fit angel eyyes - I am guessing the same could be done with the rears but I havent looked at a rear cluster for ages so cant remember.
If they passed the MOT and they still work to the naked eye I would potentially ignore it - failing that spursfaninacoupe probably has loads
