Wideband kits
Z
zedonist
Guest
Daz is running a supercharger, as the air pressure rises you need to match this with fuel and ensure the air fuel ratio is the same from idle through to wot. Usually this simply done with a rising rate fuel pump / regulator, the piece of kit in the post monitors the air fuel ratio.
