Which Antifreeze?
Paul Rice
Doncaster
Z4 2.5
What anti freeze is everyone using?
Does it matter?
Z4 2.5 with 118k on the clock
Zephyr
OEM BLUE._
I am so confused on colours, types, black magic abilities etc, so I just use what the book says.
mwpe
Camberley
I always use the OEM blue, there are so many different types out there but I prefer to stick with what it came with.
TriumphZ3
Just to resurrect an old thread (rather than start one!!) I suspect my 1.9 Z3 engine has been filled with plain water, unless the BMW antifreeze is totally clear? No colour at all and feels like water...
I have stocks of both red and blue antifreeze, I'm going by the above and will use the blue glycol based stuff I use on my Classics in a 50% mixture, if that's ok?
Either, just not a good idea to mix different colours, but I'm sure you know this.
If you have blue, use that.
Well now hang on there Tony, this day and age ignoring pink is a bit of a controversial thing to do. :whistle: 😁
TriumphZ3
Complete noobie question here - how I love to be able to say that and admit I know sod all - but what colour is original BMW antifreeze? I was convinced mine was pure water, today I siphoned some off into a clear jug and it's a very faint pink tinge. Now that might just be very weak pink OAT antifreeze, far short of 50%, but I'd like to make sure it's not the 'proper' BMW stuff and meant to be like that. Asking first saves a lot of time and money later...
Zephyr
Oem antifreeze is dark blue and diluted 50/50 with distilled water turns to a nice turquoise or light blue.
they now sell a green one for modern engines.
PhilH67
Derbyshire
if you mix them does that mean that it's non binary anti-freeze, or you could put blue in and say it identifies as pink
Zephyr
Probably a good idea to drain as much as you can of that dodgy looking stuff, and then flush it a time or two. And then faff about bleeding it all. Yeah, we've been there before, haven't we now.
Looks like rusty water if you ask me…
:banghead: Don't get me started! ..................... =))
TriumphZ3
Definitely not rusty water, I know what that looks like. Ever drained a 60 year old Triumph?
Now you've done it, though.... mentioned the B word, as in bleeding. I don't like the way you make it sound like a nightmare... :) I'll suspect there's a guide about here somewhere?
Brian James
Nr Lincoln UK
1.9 M43 B19
OAT = Organic acid technology and should not be used on classic engines and definitely not mixed with Glycol (Blue).
BMW recommend blue glycol and that is what was in my car and what I replaced with when doing a major service.
Anything else should be drained out, flushed through and then an antifreeze mix made up using distilled water. If you use anything else, it will casue precipitation of salts (especially in Lincolnshire where the water is hard) which will have its own effects on the cooling system. If you are in a hard water area do not use tap water for the flush through - use distilled water by displacement washes by emptying and filling the cooling system in the normal manner.
