Hi help can anyone tell me where I can source wheel sensor plug including the loom end which fell to bits as I tried to remove it thanks
Hi thanks for that sure I seen them on a site but cannot remember where it was, the complete plug both parts oh well looks like it's the breakers for meHave had a look at listings on the OEM parts site and failed to find the loom socket listed, if BMW do not supply a replacement then try a breakers for the socket which would require it being wired into your broken end by solder jointing and shrink wrapping the joints to make it waterproof. If you are removing the actual sensor expect to break it and have a replacement ready, you can find them on Ebay for reasonable money. The sensor is a tight fit and corrosion seizes them even more in place often requiring them to be chiseled out which destroys them.
This is the plug off the car, I've just cut it off!That's the plug that comes with the sensor as a complete unit. I think it is the female socket she wants,but could be wrong!
I may have one @Jane Blythe, I'll go have a look
Here you go, is this what you are looking for?
If it is Pm me you address and I'll post it to you.
