wheel purchase and D.I.Y refurb before and after pics
Discussion in 'General Banter' started by joey, Dec 28, 2013.
  1. joey
    joey Zorg Addict
    British Zeds The M44 Massive
    May 17, 2013
    411
    208
    59
    Guildford
    Model of Z:
    1.9 16v M44
    IMAG0255.jpg got these style 18 alloys from quarry motors in sheffield for £130 delivered..as you can see from the before pics they were in shabby shape, so over 3 days or so I sanded them down with wet and dry then primed and painted them. IMAG0246-1.jpg
    looks much better IMO than the pepper pots that were on it, the set up is is square with 225/45/17 all round maxxi victra ma-z1 on the rear and bridgestone potenza'a on the front all part worns with 7-8mm of tread balance and fitted for £90!...handling and grip is much improved and I really cannot get the back to step out at all...even in the wet its very planted and much more "chuckable"....I still have a slight difference in ride height as before, it is slightly lower driver side rear, but not as bad as I first though....an interesting piece of info I discovered after some research.....
    the handbrake when engaged can "jack up" one side of the vehicle making it look lopsided from the rear, so I put the car on some flat level ground and disengaged the handbrake and had a look and right enough the disparity from left to right was almost gone..its very minimal (about 1cm) and I suspect will be ironed out with replacement coil springs.
    next on the list is water pump replacement and seat bushes...(will be in touch aceman)
    and have some powerflex bushes going on the wishbones in the next week or so..
    • Like Like x 3
  2. zedwheels
    zedwheels Zorg Guru (IV)
    Supporter British Zeds
    1,808
    775
    162
    South Wales.
    Massive difference it makes to have nice unmarked wheels. :scorecard:
  3. allan
    allan Zorg Addict
    British Zeds East Anglian Crew
    Feb 16, 2012
    148
    40
    53
    bradwell
    Model of Z:
    z4 2.2i se
    very nice, a good job done ;)
  4. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,221
    714
    156
    Wakefield
    Model of Z:
    ///M Roadster
    Excellent job, those are one of the best looking standard wheels for the Z3 good choice I had them on my 2.8.
  5. Stormy_be
    Stormy_be Zorg Guru (I)
    Belgian Zeds
    Oct 29, 2013
    745
    470
    97
    Belgium, ieper
    Model of Z:
    Z3 2.8 Roadster
    Really nice wheels. Changed the looks of the car completely.
    The difference some sanding and paint can do to a set of rims. Good job ;-)
    Koen
