Wheel centres
Sp02zbr
Sent off the wheels to be refurbed and the centres were past their best. So made new ones at work
Had to sand down the badge due to corrosion
Need to print another mil and half bigger. But look much better.
These caps are over engineered
Maniot 64
Kalamata
Had to sand down the badge due to corrosion View attachment 83388 View attachment 83389View attachment 83390
Nice work...are they 68mm diameter centres ? These seem to be a common size for many wheels esp OEM types.....other diameters are harder to source....have found a supplier in Croatia for 62mm diameter logos for my 'Borbet' centres....mind you, they havent turned up as yet!
Sp02zbr
62mm to the inside of the trim.
64mm to the edge of the disk.
