What to look out for Z4
Alan W
Bexley, Kent
Z4 Coupe E86 3.0 si
As said in other post lm going to view a Z4 tomorrow.. apart from the roof operation what else should l look out for? What are their other faults and weaknesses of note?
Hi Alan, best advice really is to make sure that everything the car has, works. When I bought my car I was aware that the Navigation disc was missing and that the CD multi-changer cartridge was also missing. I replaced the CD cartridge in Florida for £25 as opposed to £50 + from BMW in the UK. The Nav disc can be got in the UK too. Make sure the roof operates as it should but also smoothly too. Central locking, elec. windows any thing and everything. Road test keeping an eye on the temp. guage, check oil level and oil clean? Service history, M.O.T. history. Tyres for wear, a good sign of hard use if edges are well worn (like mine) check for brake judder too it may need discs and pads. See if AC is cold, if only cool may need re-gas. Good luck with it mate.:)
Redline
Nuneaton
E89 20i msport
All the usual stuff as Tony said but also - Check the rear springs. Well known for snapping off near the top.
billz
Langley Mill
Also lift the bonnet before starting then check the engine on idle when cold listen for any kind of rattle could indicate Vanos or Disa require over hauling
raymond
EAST SUSSEX
Z3M
As above but do the usual MOT history check. Pre facelifts can suffer from "sticky" steering so take the car out for a long run and check the steering is alright when warm. Also try a motorway run to see if the car is stable at speed. Check all the warning lights go off and all electrical things work. Thermostat housings can fail along with water pumps so look through the service records to see if they have been replaced. A good sign is low owner numbers and matching tyres.
raymond
EAST SUSSEX
Z3M
You now know what a bad one looks like so it was not a total waste of time !
mwpe
Camberley
The main one is that they are not a Z3. :ymdevil:
ppavuk
Balsall Common
Z4
make sure engine runs well, make sure bodywork ok. Suspension - make sure you have a budget to replace it in first month of ownership.
Merlot
Surrey
E85
I had no idea what to look for, but I just wanted this specific car. So in the first 2 months of ownership I changed all the bushes, the run flat tyres were too harsh so they were changed, the rear springs, the steering system was sticky, so that was repaired exorbitantly, some body panels were loose so had them reattached, a new starter motor in Denmark and last, but not least a new stronger battery. The odd warning lights come on such as the ABS and power steering, but it has not affected the performance, although before the MOT next year, I'll get it sorted.
I love the car and will spend what is needed to keep it running sweet and allow me to drive it hard and fast - safely!!
Merlot
Surrey
E85
I will ask my mechanic when I next see him. What I do know is that the steering column was sent to somewhere near Sheffield to be reconditioned.
raymond
EAST SUSSEX
Z3M
The new unit is £2500 plus VAT from BMW . I converted mine to hydraulic steering instead
ZedM
Derbyshire
Z4 2.5i
Leaking valve cover gasket is another common fault. Look for oil collecting just above the exhaust manifold at the end nearest the firewall. Not a difficult fix but worthy of negotiation if evident.
What did you do to fix the steering ?
Have a look at my thread. I removed my whole column and stripped it down. The locking ring between the motor and column is to blame for the issues.
Too loose - wandering steering
Too tight - Notchy feeling hard to central
Merlot
Surrey
E85
How do I get to the locking ring. Would it be a mechanic job? or is it easy?
