What on earth is this?
GeoffZ
M44
So, both sills are off and much of the car in bits and I was just having a bit of a clear up and found this white nylon thing under the car. I don't remember it so was wondering or hoping someone on here might be able to identify it. It is quite possible its unconnected with the Z of course but . . .thank you in anticipation
Dont remember seeing one
It does look familiar but I can't remember where from.
Well as I am a saddo I have check Real OEM and cant find it. Probably off your new washing machine :whistle:
Sean d
Lincolnshire
I have stripped and rebuilt a number of z3s and that's not off one ;)
Redline
Nuneaton
E89 20i msport
No idea what this could be - looks like it could be a nozzle out of some pipe/spray device.
Someone will know. Couple of months ago I found something that had been taken to my son's amongst a whole load of stuff but neither of us recognised it. My son asked on Reddit (I think - not a site I use but common among the younger generations). Took about two months but someone came up with the answer. Happened to be the tool to tighten the mincer attachment on the food mixer.
Might be worth a try there.
https://www.reddit.com/r/whatisthisthing/
GeoffZ
M44
Fascinating and thank you for the responses. Fairly convinced now that its not off my Z and am beginning to believe it might have been planted by my wife to confound and confuse me. She has a wicked sense of humour.
In that case keep it till she's long forgotten about it Geoff.;)
You've got me curious.
Can we get a picture of it other way around.
Looks like a mounting clip for a self tapping bolt or screw ( the bit pointing up is the bottom)
GeoffZ
M44
Workshop all locked up for the night now so will take a couple of different photos in the morning. The centre hole though, doesn't go all the way through so the base that it is sat on, is a solid disk.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Looks like a doofa off a wotsit
GeoffZ
M44
Ok so I have taken some better pics of the offending item. The hole in the middle doesn't have a thread and doesn't look as if its had a self tapper screw or bolt in it. The hole doesn't go all the way through and is blind at the circular base end. It wasn't oily. In the absence of a name or purpose, I guess the Wotsit may have to do . . . for now.
Redline
Nuneaton
E89 20i msport
Almost certain it is not a wotsit - It's a thingamabob! Possibly a left handed one at that ;)
mrscalex
I’ve literally stripped shells to the last nut and bolt and save/filed everything. I don’t recognise it.
If it’s off a Z3 I would think it’s something that’s normally contained within a bigger unit and goes unseen. Eg a motor.
Jack Ratt
TRURO, CORNWALL
I have seen "blind" connectors with a similar design but they are usually made of metal. When they are fitted you can't see anything on the external surfaces of a cupboard or a table or some other type of flat pack furniture type stuff.They fit into a profiled hole and are then twisted to lock in.
Redline
Nuneaton
E89 20i msport
You might very well be onto something there. :thumbsup:
GeoffZ
M44
Gentlemen thank you. Thats good enough for me and now convinced finding it under the Z was a red herring. No doubt one day I will find something in my garage is missing a mystery but essential component but at least I can confidently now get on with the job in hand.
