I have a sneaky suspicion this may be something a lot of us do not do by the book.
I usually put them on with the lollipop parallel with the wishbone and then let it find it's own place when bolted up.
But this is not necessarily correct. For instance on the rear drop links they need to be installed at 76 deg to the ARB. And anything used to slip the bush on should be allowed to dry/evaporate to 'fix' the position before installation.
So what is the correct way to install the lollipop? The 2 wishbones I took off were different. One appeared to be original BMW and clearly shows the lollipop at an angle. That's this one.
The other was a replacement and was parallel with the wishbone.
The majority of How-Tos gloss over this. But I have seen a couple where the suggestion is if you don't get this correct it affects handling. Then they don't explain what correct is...
