Guys I have my centre console out at the moment and have a few lights out, is there a decent upgrade or just stick with standard,
Thanks
Thanks
Do you know what the fitting is, I think I have seen T5 somewhereI would consider warm white leds, they are never broke as bulbs do, so you wouldn't need to disassemble console ever again.
No idea to be honest.Do you know what the fitting is, I think I have seen T5 somewhere
Sod that mate, £10 for a tiny bulb, thanks for looking thoughI've think they are the same as the ones in the ash tray
Give over, I'm not @Faheem,If those are the correct lamps then how about these blue LEDs
Not sure if these would fit
I really don't understand your comment Sean.Give over, I'm not @Faheem,
I was referring to the age thing mate, blue leds IMO are for the boy racersI really don't understand your comment Sean.
If not blue to match your seats they do the same LED lamps in white
I did consider them mate, but if I can make them fit I would have to do the cluster as wellWhat did you think to the white leds ?
I guess they could be to bright
Forgot to add that I never drive it at night, I'm just getting everything as it should be.I did consider them mate, but if I can make them fit I would have to do the cluster as well
I have tried to go this route Sean. I had to break the old bulb out leaving some of the wire to solder the new cap-less one onto. They don't just pull out - well mine didn'tJust found these after doing some research on .net, apparently the bulb will pull out of the holder and can be replaced with an Osram 2721, £5.88 for ten
http://www.ebay.co.uk/itm/10x-Genui...912343?hash=item51c8d76d17:g:cWIAAOSwe7BW09VG
Bloody .net, someone said his pulled out and he put them together with out solder, Its not a problem though if I have to solder them, did yours work ok once solderedI have tried to go this route Sean. I had to break the old bulb out leaving some of the wire to solder the new cap-less one onto. They don't just pull out - well mine didn't
Bit fiddly, but yes they have been OKBloody .net, someone said his pulled out and he put them together with out solder, Its not a problem though if I have to solder them, did yours work ok once soldered
I can do fiddly mate, especially as I will be saving £9 on every bulb , I have at least 4 to changeBit fiddly, but yes they have been OK
I did three......I have at least 4 to change...
