Continuing on from my caliper seal replacement I fitted the new front pistons and seals yesterday so now front brakes work again. Had a little test drive and no vibration again, you forget how good they are to drive.
Today was spent replacing the 4 flexi hoses on the rear brakes. I got them a while back but finally dry enough to get them replaced. The ones to the calipers were easy enough but the body to rear beam were a pain to get at especially as the exhaust runs just in the way, still won't be beaten.
I also had the rear discs off to have a look at the handbrake. Back plates are in great nick and the shoes look nearly new but not surprising as the handbrake is probably the least used bit of the car as it is an auto.
All back together but will have to bleed the rears tomorrow a has to stop to watch the 6 nations.
