zielritter
Hi, All -
Using the holiday break to do a little preventative maintenance on my '99 2.3. I ordered a new water pump with metal impellers with the expectation of replacing what I thought would be the stock water pump with the prone-to-failure plastic impellers. However, to my surprise when I got the stock pump out it appears to have some sort of metal impellers already! Can someone help me out here? As the picture shows the impeller part is stamped BMW 173135 and clearly looks to be aluminum (albeit a thinner variety than the aftermarket OEM equiv I purchased). Is this one good to go and I can return the other one I bought?
