Water-less Coolant is it any good?
I've been toying with this conversion since seeing it on wheeler dealers (most of you probably have seen it too) so I have been doing a bit of checking and found this on piston heads posted by Opieoilman. Makes interesting reading, sorry if this is not new or you've seen it before.
This is something that has come from Red Line's suppliers.
Many concerns have been raised to us in recent months regarding the effectiveness of Waterless coolants and the inherent dangers they may possess. We have spent some time researching the product and would like to make all our customers aware of our findings.
Waterless products are 100% glycol, some are 100% propylene glycol, and others are a mix of propylene glycol and ethylene glycol. They are slippery when spilled or leaked onto tarmac. Assuming a baseline friction co-efficient reference of 1.00 for dry pavement, the friction co-efficient of water is 0.65. The friction co-efficient of Waterless products is 0.16, four times less than water. Some race circuits in America are now prohibiting the use of engine coolant that contains ANY glycol due to this fact.
The other and more pressing reason that Waterless products are prohibited at race circuits is that they are flammable. With flash points in the range of 110-130°C if the Waterless coolant were released at or above the flash point, it could ignite. Coolant temperatures can be observed in this range during actual operating conditions, making this a real risk. Reports have also been made of damage caused by glycol coolant fuelled fires, in some instances, destroying whole cars and resulting in thousands of pounds worth of damage.
The NHRA rule change regarding glycol coolants was the result of a terrible fire where the competitor was using Waterless coolant in his car. The engine pushed a head gasket and the coolant caught fire which came under the seat resulting in a cockpit fire. Glycol coolants are now prohibited in the NHRA. In another case the Motorsport South Africa ASN prohibited the use of glycol on safety grounds “In the case of both cars and motorcycles, the use of glycol-based coolant additives is prohibited.”
In addition, the operational downside is the decreased ability to transfer heat compared to water based coolants. Waterless coolant should never be advised in applications where heat issues are apparent, Waterless coolants will only compound this problem as they lack the necessary heat transfer properties to provide a solution.
Although the product is a very good corrosion inhibitor, it will not adequately protect an engine when overheating. The Waterless coolants cannot transfer heat as efficiently as water, thus causing an engine to run hotter. The engine will continue to run hot until a critical component fails as the boiling point is so high.
To summarize:
Engines can run 45-60°C hotter (at the cylinder heads) with Waterless products.
Stabilized coolant temps are increased by 15-25°C, versus straight water with Water Wetter.
Specific heat capacity of Waterless products ranges from 0.64 to 0.68, or about half that of water.
Engine octane requirement is increased by 5-7 numbers reducing engine horsepower by 4-5%.
Viscosity is 3-4 times higher than what OEM water pumps are rated to accommodate.
Coolant flow rate through radiator tubes is reduced by 20-25% due to the higher viscosity.
Race circuits are starting to prohibit Waterless products because they are flammable and cause a slippery surface hazard when leaked.
When speaking to a classic car specialist recently the subject of Waterless coolants was brought up.A Waterless coolant manufacturer had given them product sponsorship ahead of classic Le Mans 2012, in FP1 the car stopped on track with smoke billowing out of bonnet. On closer inspection the coolant had plasticized and warped the head, the coolant then passed through the head gasket hydraulic locking cylinder one. The damaged cause was very costly and ended the team’s weekend early, it is not a product they would recommend or use again.
5harp3y
seen it before on wheeler dealers
looks good, but is expensive, if the car isn't running hot i don't see the benefits over standard (cheaper) coolant really
Ianmc
New Forest
Z3 (M44)
snake oil...
a great marketing campaign getting people to spend £100's when antifreeze and water will work just as well for our applications.
A bit like Nitrogen in tyres...
Couldn't agree more.
Nitrogen in tyres is slightly different due to its properties and does have benefits. I toyed with this coolant for a while and wondered the same, what do you actually gain from going waterless? Ok you can open the cap when its up to temp because there's no expansion. My thought was what happens what you have an overheating issue the first give away is the steam which you wont get.... Would it damage the engine or components. I couldn't make my mind up.
A very interesting and informative read. Thanks.
Redline
Nuneaton
E89 20i msport
The benifits don't seem to sufficiently outweigh the risks for me, certainly not for use in car engines.
We use this kind of stuff in cooling some transmitter systems - they don't run as hot, are running 24/7 and the consequences of corrosion are much greater when you get different metals in the system.
But, while using something flammable that is completely contained but at temperatures much higher than the ignition point is fine, it's fine only until it becomes uncontained. The benifits thendon't seem that great and often the consequences somewhat inconvenient.
