Water in boot of my Z3
Barry Gadd
Woking Surrey
Z3 1.9L
I've sealed one leak by adding sealant to the boot mounted rear light but now find lots of water gathering at the back of the boot area (the area directly under the rear screen)
I'm wondering if water is finding it's way down the rear window and not draining away as perhaps some drainage channel is blocked....
Any ideas???
PeterJ
Hong Kong Zeds
Hong Kong
Z3 2.8 Roadster M52B28
There is a rubber that goes along the back between the soft top & the car body. Mine used to leak with water in the same place as you described. I replaced the rubber and now no more leaks... don't know the part number and was ordered directly & fitted by my engineer so I never actually saw this particular rubber (!) ...anyway, it was not expensive & did the job.
Dino D
Kent
2.8 Manual
Following advice from a forum member on .net I have almost cured the leak in my roof with this method:
"CAPTAIN TOLLEY CREEPING CRACK CURE" found in eBay.
It's a marine product.
I applied it in between the seal between the body and the hood.
I removed all the carpets to trace the leak (and dry it out) and could actually see this liquid pooling in the boot as it made its way through the gaps (it's milky but dries clear). I think I had some big gaps so have had to apply it a number if times over a few days/weeks - not yet 100% leak free but almost there so will keep trying.
At around £10.00 for 250ml a cheap and labour free fix.
I have allied wit with the hood closed/open/half open. Not sure if it made much difference (the position of the roof).
Barry Gadd
Woking Surrey
Z3 1.9L
Hi,
Many thanks for the replies. I'm still trying to sort out why my Z3 won't start (It's a fuel problem maybe relay or pump; hope to check both this weekend) After that I'll get cracking on sealing the hood.
DeanjayZ
Hi mate, can you tell me a bit more please. I have a crazy leak going on, from the inside boot lid being covered in water, to the back of the boot carpet wet. Don’t suppose you’ve got any pictures?
Dean.
Rudyrov
Phoenix, AZ
2.8 L Roadster
My car was leaking water through the taillight seal and the radio antenna seal.
I have also read that the center tailight can leak when it rains.
DeanjayZ
is there a seal on third brake light? Mine is a 2000 year - facelift?
