Had this light come on can anyone please tell me what it means please?
Not sure it is HT, more like a automatic transmission advisory light.Hi Tony, that's your break pads.
Tony - as your car is an auto a couple of thoughts come to mind....more like a automatic transmission advisory light.
By the fact that the light is yellow/orange this is an advisory item which basically means please sort the issue at your earliest convenience unlike a red warning lamp which means stop the car and get the issue sorted before proceeding.Tony - as your car is an auto a couple of thoughts come to mind.
Our 2.2i was extremely sensitive to fluid levels (especially sump oil) and would flash warning lights way before the levels got anywhere near minimum.
Given you comment about "sharp left entering the workshop" I'm wondering whether it could be low on power steering or automatic transmission fluid?
I would certainly check the simple things one before heading towards the stealers
Only do one at a time though otherwise you'll not know which (if any) solved it!
Terry
Electronic transmission control module
If the indicator lamp comes on, there is a malfunction in the transmission system. Bring the vehicle to a stop, select transmission position "Park," set the parking brake and turn the engine off (ignition key to position 0). Wait a few seconds, then start the engine. If the indicator lamp goes out again after a few seconds, normal transmission performance has been restored. Continue to drive normally. If the indicator lamp does not go out, all selector lever positions can still be selected. However, the vehicle has limited performance in the forward drive positions because the transmission utilizes only 3rd gear (position 1 or 2) or 4th gear (position 3 or "D"). In this situation, avoid severe loads and take the car to the nearest BMW center without delay.
