Wanted Wanted x2 Genuine AC Schnitzer 7mm spacers for the type III alloys with extended wheel bolts and rear extended bolts
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
Hi there,
After a pair of Genuine AC Schnitzer 7mm spacers for the type III alloys with 10 extended wheel bolts for 7mm spacers..
Also after 10 extended bolts for 10mm spacers (I have the 10mm AC Schnitzer spacers)
For a Z3m (e36 will work)
Any links would be appreciated..
Thanks for looking :thumbsup:
Pond
Spaldingski, Lincs
3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
Why do you want ACS spacers? They will be expensive (as are all ACS branded parts). A 7mm spacer is only a shim. Basically a round piece of ally with holes drilled in it. As long as it has the correct hub hole and bolt hole spacing, anything will do the same job IMO.
