Decided to sell this as the wife wouldn't be happy with it behind her seat,
I bought it as ex display and apparently it was never switched on, comes with all leads but no box
£65 plus postage
The Optisound range continues to advance what is possible from a compact bass solution with the OptiSound subwoofer enclosures. These super slim bass enclosures are designed to fit in even the smallest of spaces whilst still having the big bass presence that people have come to expect from VIBE. Small, sleek and lightweight, these enclosures will fit into any available space, behind a seat, under seat or tucked away in your luggage compartment.
The OptiSound enclosures are perfect for those looking to add bass to their system but want a stealth install or donât have the space to spare for a large enclosure. The labyrinth slot ported bass enclosure features VIBE Audioâs anti-resonance bass support system (A.R.B.S.S.) to minimize vibrations and enclosure resonance and can deliver an incredible amount of fast, tight bass from such a compact unit.
The Optisound Auto 8 is available in both an active and passive model. The active model contains a built in amplifier, making it the perfect one box bass enhancement upgrade to complement factory fit speakers. The VIBE OptiSound active enclosure with the VIBE PowerBox Bass 1, a lightweight Class AB mono bass amplifier with a separate power amp for superior sound quality. Combined with the new extruded aluminum heatsink this also ensures efficient dispersion of heat. MOSFET Power allows high switching speeds and even greater stability than other FETs to improve overall performance. This small but capable bass amplifier is capable of delivering up to 900 watts peak and both high and low level inputs allow maximum compatibility with all types of headunit.
The newly designed Optisound subwoofer has been specifically designed to operate best in the OptiSound enclosure, giving tight fast bass and impressive presence from a compact enclosure. The A.R.B.S.S system reduces enclosure resonance and vibrations, to ensure that bass is the only thing you hear. Integrated mounting brackets make installation easy.
Product Specifications
£65 plus postage
- Height: 3" (75mm).
- Width: 10.6" (270mm).
- Depth: 15" (380mm).
- Driver: Liteair 8".
- Impedance: 4 Ohms.
- RMS Power: 300w.
- Peak Power: 900w.
- Turbo Ports: Labyrinth Port.
- Characteristics: Deep Smooth Bass.
- Active Amp Built-In: PowerBox Bass 1.
