VANOS exhaust camshaft, end position not reached dtc 68
daverav
Brentwood Essex
3.0 sport
I am getting the above fault code any ideas the car is driving a bit flat!
cheers
Brian4
Near Grantham
Z3 3.0i Auto
cheers
Not a great deal of help I'm sorry but if you put your post title into google it comes up with a few results and the consensus seems to be leaking vanos seals or sticking vanos solenoid.
I have no experience of this but you could try contacting Mr Vanos for his advice.
http://www.mrvanos.com/
My guess is possibly a seal leak which would lose pressure not allowing the Vanos full travel?
oh dear sounds like i may need to pull it apart again :(:(:(
Possibly Dave but get a second opinion before you do so mate.
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Could be a sticky solenoid. Swap it with the inlet solenoid, clear the fault code and then see if the fault appears on the inlet.
I would also check the movement of the shuttle valve while the solenoid is off.
Eddie Zedder
Z3 2.0
Right took both solenoids off cleaned them both in my ultra sonic cleaner
Put them both in cleared the fault codes and ........ it only bloody worked back to its normal self ! Happy days
Great result :thumbsup:.
Nice one Dave:thumbsup:
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Great stuff, was just about to say solenoid but you got there first!
On the M sometimes the soldering breaks to the little chip board. Not sure if it's the same on non Ms
