I'm looking to use a car cover on the z3 whilst kept in the garage over winter but also whilst the car is on the drive during the summer months. Is there anything I should keep an eye on or any additional advice to keep the car in top condition?
I wonder if you could wedge pieces of foam in the bonnet and the bootlid to act as pieces that take the 'pressure' from the cover. Shouldn't be too hard to make a piece few pieces that take the blunt of the wear when the cover is on, shouldn't it?I could show you a horror story of a car that had a cover fitted. It's one of my project cars and now requires a rear end respray because of it. And that's after trying to wet sand the scratches out and machine polish. Of course that enabled me to buy it cheap![]()
Yeah my car has quite a few marks that have the same pest origin :/ the new hard top also has the same problem.Mine is under a cover in the car port. Always make sure the car is clean before it goes on. Id prefer not to have it in a cover to be honest but some pussy put scratches down the bonnet![]()
That's exactly the sort of information I was after thank you. I've ordered a stormforce cover and a few other bits which will hopefully help keep the car in good order.I put a lightweight cover on my car in the garage through the winter, just to keep the dust off.
Other winter storage items are a trickle charger for the battery and inflate tyres to 40 psi to protect the sidewall from deforming. Also consider a dehumidifier (silica gel type or old sock filled with salt) in an open plastic tub inside the cabin.
Put the car in gear and leave the handbrake off, anti freeze should of course be up to strengh.
Opinions vary on how much fuel to leave in the tank. Some say full to prevent corrosion (but Z3s have plastic tanks), other say minimum as the fuel degrades. I am in the second camp.
Hope that was what you were looking for.
Is this the one people are getting?Hi guys following the thread as I was about to create one in regards to a outdoor fully water proof car cover.
Planning to get a garage but until then could do with a full car cover, can anyone confirm me if the Stormforce one you guys mentioned is breathable, interior is cotton lined and has fitting stripes for underneath the car?
Is it a snug fit?
Where to ordered from and roughly how much?
Thanks in advance
Rui
