Dado
- Joined
- Dec 25, 2017
- Points
- 65
- Model of Z
- 2.2 mtec
Hello all, Brain picking time again, my 2.2 Z3 has 56000 miles on it, the front brakes have EBC green stuff pads fitted (a bit more than a year ago) so only 1500 ish miles with them, the brake fluid was changed a little while after.
Braking is fine normally but occasionally when 'making progress' they fade quite noticeably, this is after several very hard braking instances, a couple of times causing enough concern that I was actually going to stop (the smell of burning brakes really strong).
After running at a slower speed for a mile or so, all is back to normal.
My thinking is to put some larger discs with maybe 4 pot calipers on, so am wondering if anyone here has done this and if so what was used.
Have considered not driving at this pace, but hey when the opportunity arises can't help myself, it's part of the reason I bought a Z3 (dry road, roof down, adrenalin up) instead of a Nissan Micra.
Milton Keynes roundabouts add to the need for braking more than usual on a spirited drive too.
Looking behind the wheel there seems to be room to fit a slightly larger disc and caliper in there but have no idea what might fit, maybe someone has used an alternative make of disc (tarox, EBC or other) that has worked with an alternative pad to green stuff.
Did consider the next grade up of pad but wonder if the cold/low speed braking would be affected and compromise 'going to the shops' braking.
Just looking for ideas really, I know it makes me appear to be another irresponsible nutter on the road but I really do have some skill driving and riding in all sorts of situations.
Cheers Dave
Cheers Dave
