Hey all,
My 2.2L Sport Z3 is in need of new front pads and discs, so given I am about to replace I am considering upgrading if I can, and its not too expensive....and also only if its worth it.
Reading around the forums I see lots of people upgrading from the 1.9L->3.0L set requiring new Discs, Calipers and Carriers. I couldn't find much info upgrading from the 2.2L->3.0L kit however.
As I understand the 3.0L runs 300 x 20 mm front discs, the 2.2L runs 286 x 20mm front discs.
My questions are:
Help much appreciated!
Cheers
Billy ( Nabs )
My questions are:
- Would the upgrade even be noticeable ( over new 2.2L kit )? I'm driving A/B roads on the odd tour around the country.
- Do I only need the calliper carriers to make this work? Or is this a straight swap for just discs?
- I'm a novice at doing car DIY, if carrier switch is required is this an easy thing to do?
- Do I also need to change the pad sensor at the same time or can I re-use?
Cheers
Billy ( Nabs )
